OSPFv3.NbrMgr.DropPktNoMatchIf
Description
An OSPFv3 packet with a link local or multicast destination address was received. It was attempted to match it to an interface (rather than a virtual interface or sham link). No interface could be found with a matching interface index and instance ID. The packet was dropped.
Remedy
If the problem persists and this log is unexpected check configuration. In particular check that the instance ID is correct on the specified interface.
Severity
Info
Message Text
%p1%%p3% dropped a link local or multicast packet on interface with instance ID %p4% as no i/f was configured with that i/f index and instance. This log may be expected if multiple OSPF instances have been configured on this i/f. Diagnostic information for support: Packet data = %p2%
Message Parameters
Name Type
p1 String
p2 HexPktByteArray
p3 String
p4 uInt8
